nat port 5060
Discussion in 'Windows' started by napster363, Sep 20, 2015.
  1. napster363
    Sep 20, 2015
    hello, i have installed 3CX Phone System v14 on a windows server 2012 r2 with a firewall pfsense. I have a problem when I go to do the firewall checker because I failed to Port 5060 while the others are all open. The strange thing is that there is a nat and the rule on the firewall for the port 5060
    11,095
    327
    Could there be, or could there have been, another SIP device set to use that port? Are you using a router that was supplied by a provider that also offers a VoIP service?
