Need a 4 SIM 3G Gateway
Discussion in '3CX Phone System - General' started by abacusadmin, Apr 7, 2017.
  1. abacusadmin
    Jul 21, 2010
    16
    I have been using a 2N VoiceBlue Next GSM gateway with 4 SIMs in it that has worked well with 3CX for a number of years.
    The problem is that here in Australia the telcos are shutting down the GSM networks so I need to find a 3G or 4G gateway as I want to send outgoing calls to mobiles phone out through a physical gateway. I want something that takes 4 SIMs.
    Anyone know of a device that works with 3CX?
    10,594
    255
    You may have to do some research on which frequencies/technologies are being, or are going to be used. With 5G on the horizon, things are still evolving. What works in North America (not a lot to choose from), or Europe, may not work in Australia.
  3. gorbros
    Jun 8, 2015
    11
    7
    Hi Abacusadmin try Yeastar. I am currently using the TG200 GSM on 3CX v15 works wonderful. Go to yeastar.com have a look contact me and I will arrange for you to get one
    Regards
  4. 10m
    10m
    May 3, 2014
    26
    7
    Hi Abacusadmin.
    Please share with me how you setup your TG200 with 3CX. I'm having difficulties setting up outgoing calls on my PBX.
    Thanks very much.
  5. gorbros
    Jun 8, 2015
    11
    7
    Have you configured your outbound rules in 3CX and did you configured your ip to mobile settings in the gateway?
    Cables likes this.
  6. 10m
    10m
    May 3, 2014
    26
    7
    Thanks Gorbros.
    I got help from Yeastar support. I had set up my outbound rules on 3CX, it was the gateway that had configuration issues but we have sorted that out.
    gorbros likes this.
