Need a string REPLACE VAD function
Discussion in 'CRM / Helpdesk / App Integration' started by SWSDEV, Apr 30, 2011.
  1. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Yes, that would be useful, we're going to add a new function to do that.
    Meanwhile, you can easily create a JavaScript function to do it, and call it from an External Code Execution component.
    Regards,
