Need advice about GSM gateway and 3cx
Discussion in '3CX Phone System - General' started by bluetel2, Sep 10, 2009.
  1. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    6
    do you know what type of gateway is suggest to use with GSM gateway. I know that we can install gs gateway under patton 4112 4114, but in the market it exist some products who are the 2 products in 1, like 2N VoiceBlue Lite - VoIP GSM Gateway .
    3cx admin or developper can advice me, and said who GSM gateway is compatible with 3cx system.
    tks very much.
  2. ess
    ess New Member
    Jun 8, 2007
    133
    A lot of people use the Portech series of GSM Gateways with major success. I don't know about the 2 in 1 products.
  3. tpinnovations
    tpinnovations Member
    Jul 30, 2009
    296
    I would imagine that any of the GSM gateways that are SIP standard capable would work. Finding which ones work best however is another story which has yet to be investigated.
  4. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    663
    I can recommend a Portech also. Great quality, low price.
