Need Help changing caller ID based on client codes dialed
Discussion in 'Call Flow Designer' started by rudydm, Jan 31, 2018.
  1. rudydm
    Jan 31, 2018
    6
    Hello, I need assistance using Call Flow Designer to create an app that will prompt our helpdesk staff to provide a customer code before dialing an external number. We would also like the ability to change our outgoing caller ID based on the customer code that was entered by the helpdesk member. Any help is appreciated. Thank you
  2. voiptoys
    voiptoys Active Member
    Feb 13, 2013
    730
    126
    We already have this exact solution. Contact me
  3. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,367
    110
    Hello @rudydm,
    You can use the Authentication component to validate the caller, as explained here:
    https://www.3cx.com/docs/cfd-validate-customers/
    And then you just ask for the number to call using a User Input component, and transfer the call to the number entered by the caller.
    Changing the outgoing caller ID can only be done using the Caller ID reformatting options, but nothing can be done from the CFD regarding this:
    https://www.3cx.com/docs/cid-reformatting/
    Kind regards.
  4. voiptoys
    Feb 13, 2013
    730
    126
    Our solution will change the outbound caller ID prior to sending out the call.
