Need Help for purchasing Telephony Analog Card
Discussion in '3CX Phone System - General' started by milindsaraswala, Jan 10, 2011.
  1. milindsaraswala
    Jan 10, 2011
    Dear Sir,
    We are going to install IP-PBX in our company. Still we don't decided that we are going to install 3CX or Trixbox. But I am looking for Telephony Analog Card, which can connect to 4 lines from Ministry of Communication (PSTN Line) to my IP PBX and If in same card I can connect only 1 analog phone with eco cancellation.
    Kindly help me which model of card I should buy which can help me in both 3CX and Trixbox. If you some video how to connect then it will be very helpful.
  2. Discovery Technology
    Apr 19, 2008
    278
    The sangoma cards are fully supported in 3CX, including templates that have been tested.
    I would recommend that you consider one of these, or possibly a separate gateway device instead, such as a Linksys or Patton gateway.
    Regards
  3. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    Get yourself an external gateway (Grandstream best gxw-4104, Patton second best).
