Need Help have Problem with make_call.php
Discussion in '3CX Phone System - General' started by silentfun, Dec 16, 2007.
  1. silentfun
    silentfun Member
    Dec 11, 2006
    364
    I first get the ringing on ext 555 then i pickup the call and get wait transer message then i get transfer failed.
    outbound rule for 555 is ok and manual outbound call to the defined number works.
    http://85.***.***.***:5481/make_call.php?extnum=555&vmpin=***&to=03684887***
    I use 3CX Phone System Version5.0.3648.0 incl. manual Patch
    LOG:
    Time Function Message
    10:48:31.793 Call::Terminate [CM503008]: Call(29): Call is terminated
    10:48:28.933 Call::RouteFailed [CM503013]: Call(29): Attempt to reach [sip:03684887***@127.0.0.1] failed. Reason: Reason Unknown
    10:48:28.918 CallLeg::eek:nFailure [CM503003]: Call(29): Call to sip:03684887***@sip.1und1.de:5060 has failed; Cause: 400 Bad Request; warning: ; from IP:212.227.15.197
    10:48:00.606 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(29): Calling: VoIPline:10000@[Dev:sip:493621369***@sip.1und1.de:5060]
    10:47:56.777 CallCtrl::eek:nLegConnected [CM503007]: Call(29): Device joined: sip:555@87.230.126.104:40218;transport=udp;user=phone
    10:47:51.277 Extension::printEndpointInfo [CM505001]: Ext.555: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXP2020 1.1.4.17] Transport: [sip:85.***.***.***:5060]
    10:47:51.277 CallCtrl::eek:nAnsweredCall [CM503002]: Call(29): Alerting sip:555@87.230.126.104:40218;transport=udp;user=phone
    10:47:50.902 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(29): Calling: Ext:555@[Dev:sip:555@87.230.126.104:40218;transport=udp;user=phone]
    10:47:50.887 CallCtrl::eek:nIncomingCall [CM503001]: Call(29): Incoming call from Make Call to [sip:555@85.***.***.***:5060]
    85.***.***.*** <-- PBX public IP
    87.230.126.104 <-- public Ip of the Network where the extension is.
    212.227.15.197 <-- not shure but i think voip line provider
  2. silentfun
    silentfun Member
    Dec 11, 2006
    364
    same setting
    call (41) do not work
    call (42) work perfect
    call (43) is the incomming that was initiated with the outgoing call(42)
    here the log:
    11:50:20.644 Call::Terminate [CM503008]: Call(43): Call is terminated
    11:50:20.644 LineCfg::getInboundTarget [CM503010]: Inbound out-of-office hours' rule for LN:10001 forwards to DN:201
    11:50:18.785 Call::Terminate [CM503008]: Call(42): Call is terminated
    11:50:18.769 Call::Terminate [CM503008]: Call(42): Call is terminated
    11:50:18.207 Line::printEndpointInfo [CM505003]: Provider:[493621369*** FCT] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] Transport: [sip:85.***.***.***:5060]
    11:50:18.207 CallCtrl::eek:nAnsweredCall [CM503002]: Call(42): Alerting sip:493621369***@sip.1und1.de:5060
    11:50:17.035 Extension::printEndpointInfo [CM505001]: Ext.201: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXP2020 1.1.4.17] Transport: [sip:85.***.***.***:5060]
    11:50:17.035 CallCtrl::eek:nAnsweredCall [CM503002]: Call(43): Alerting sip:201@87.230.126.104:44638;transport=udp;user=phone
    11:50:16.644 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(43): Calling: Shared:201@[Dev:sip:201@87.230.126.104:44638;transport=udp;user=phone, Dev:sip:201@87.230.126.104:61088;transport=udp;user=phone]
    11:50:16.644 Line::printEndpointInfo [CM505003]: Provider:[036848489*** SIPGATEde] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] Transport: [sip:85.***.***.***:5060]
    11:50:16.644 LineCfg::getInboundTarget [CM503010]: Inbound out-of-office hours' rule for LN:10001 forwards to DN:201
    11:50:16.613 CallCtrl::eek:nIncomingCall [CM503001]: Call(43): Incoming call from anonymous@(Ln.10001@036848489*** SIPGATEde) to [sip:201@85.***.***.***:5060]
    11:50:16.300 LineCfg::getInboundTarget [CM503010]: Inbound out-of-office hours' rule for LN:10001 forwards to DN:201
    11:50:08.847 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(42): Calling: VoIPline:10000@[Dev:sip:493621369***@sip.1und1.de:5060]
    11:50:05.004 CallCtrl::eek:nLegConnected [CM503007]: Call(42): Device joined: sip:555@87.230.126.104:40218;transport=udp;user=phone
    11:50:01.800 Extension::printEndpointInfo [CM505001]: Ext.555: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXP2020 1.1.4.17] Transport: [sip:85.***.***.***:5060]
    11:50:01.800 CallCtrl::eek:nAnsweredCall [CM503002]: Call(42): Alerting sip:555@87.230.126.104:40218;transport=udp;user=phone
    11:50:01.488 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(42): Calling: Ext:555@[Dev:sip:555@87.230.126.104:40218;transport=udp;user=phone]
    11:50:01.457 CallCtrl::eek:nIncomingCall [CM503001]: Call(42): Incoming call from Make Call to [sip:555@85.***.***.***:5060]
    11:49:49.941 Call::Terminate [CM503008]: Call(41): Call is terminated
    11:49:47.082 Call::RouteFailed [CM503013]: Call(41): Attempt to reach [sip:036848489***@127.0.0.1] failed. Reason: Reason Unknown
    11:49:47.082 CallLeg::eek:nFailure [CM503003]: Call(41): Call to sip:036848489***@sip.1und1.de:5060 has failed; Cause: 400 Bad Request; warning: ; from IP:212.227.15.197
    11:49:46.472 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(41): Calling: VoIPline:10000@[Dev:sip:493621369***@sip.1und1.de:5060]
    11:49:42.644 CallCtrl::eek:nLegConnected [CM503007]: Call(41): Device joined: sip:555@87.230.126.104:40218;transport=udp;user=phone
    11:49:36.347 Extension::printEndpointInfo [CM505001]: Ext.555: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXP2020 1.1.4.17] Transport: [sip:85.***.***.***:5060]
    11:49:36.347 CallCtrl::eek:nAnsweredCall [CM503002]: Call(41): Alerting sip:555@87.230.126.104:40218;transport=udp;user=phone
    11:49:36.051 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(41): Calling: Ext:555@[Dev:sip:555@87.230.126.104:40218;transport=udp;user=phone]
    11:49:36.035 CallCtrl::eek:nIncomingCall [CM503001]: Call(41): Incoming call from Make Call to [sip:555@85.***.***.***:5060]
