need help!! how to transfer a call form a c470ip??
Discussion in '3CX Phone System - General' started by redoxoder, May 13, 2009.
  1. redoxoder
    Jun 14, 2008
    hello
    i m new on 3cx
    how to tranfert a call from a siemens c470ip
    thks
    :oops:
  2. galal202
    galal202 New Member
    Jun 23, 2008
    235
    Hello and welcome,
    you must have a transfer botton on your device
    or flash then acode (ex: in linksys *98)
    transfer depend on your device
  3. Hanzz
    Jun 11, 2009
    11
    Hello everybody,
    Redoxoder, have you already solved tranfer call from Gigaset 470IP ?
    I have the same problem. The new firmware (2184), SIP refer = ON....but nothing happends when I try to re-connect the call to another extension.
    I tried all variable settings on extensions in 3cx (header,re-invite, audio), no success.
    I' am new with 3cx and I consider buying it,but this is big obstacle.
    Thank you very much for any help.
  4. voipbaennjer
    Jul 10, 2009
    44
    Select "Transfer" from the Menu
    This should do it, according to the Siemens support team
