need help on 3cx question
Discussion in 'Windows' started by davidlee, Jul 30, 2016.
  1. davidlee
    Jul 7, 2016
    8
    is SIP protocol itself includes Codecs(audio) description ? im quite confuse this.. is suppose SDP is handle audio codecs description right instead of SIP ? appreciate anyone can help on this ? :D
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,387
    88
    VoIP Generally consists of 2 Protocols, SIP and RTP. SDP is a part of the SIP.
    You can even see this if you capture a call in e.g. Wireshark, and you will see that the SIP information is in the Message Header, and the SDP information is in the Message Body.
    But yes, the SDP is where the Media Negotiation happens :)
