need help with mp-118
Discussion in '3CX Phone System - General' started by css, Mar 6, 2008.
  1. css
    css
    Aug 15, 2007
    21
    I am currently running version 5.1.4078
    I have just setup a audiocodes MP-118 with 4FXS, 4FXO. Everything registers as soon as I add Pstn lines but I can make a call. All I get after dialing is a busy signal.
    Here is my log.
    07:32:50.281 AuthMgr::eek:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 192.168.1.4 tid=-2fae9605 cseq=REGISTER contact=3682@192.168.1.205:5060 / 35604 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    07:32:49.968 printDetailedInfo [CM502001]: Source info: From: "3682"[sip:3682@192.168.1.4];tag=95ef445a3d122afdo1; To: "3682"[sip:3682@192.168.1.4]
    07:32:49.968 evt::CheckAuth::not_handled [CM302002]: Authentication failed due to unidentified source of: SipReq: REGISTER 192.168.1.4 tid=-2fae9605 cseq=REGISTER contact=3682@192.168.1.205:5060 / 35604 from(wire)
    07:32:48.218 AuthMgr::eek:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 192.168.1.4 tid=ac153450336 cseq=REGISTER contact=4372065@192.168.1.5 / 3444 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    07:32:46.171 AuthMgr::eek:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 192.168.1.4 tid=ac148323452 cseq=REGISTER contact=2003718@192.168.1.5 / 3444 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    07:32:45.406 AuthMgr::eek:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 192.168.1.4 tid=ac146644130 cseq=REGISTER contact=2003682@192.168.1.5 / 3444 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    07:32:38.750 AuthMgr::eek:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 192.168.1.4 tid=ac129763224 cseq=REGISTER contact=4372025@192.168.1.5 / 3442 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    07:32:26.390 FaxCfg::updateContact [CM504008]: Fax Service: registered as sip:888@3CXPhoneSystem with contact sip:888@192.168.1.4:5100;user=phone
    07:32:25.421 FaxCfg::updateContact [CM504010]: Fax Service: unregistered contact sip:888:5100;user=phone
    07:32:17.406 AuthMgr::eek:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 192.168.1.4 tid=ac76392715 cseq=REGISTER contact=4372065@192.168.1.5 / 3442 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    07:32:15.343 AuthMgr::eek:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 192.168.1.4 tid=ac71262639 cseq=REGISTER contact=2003718@192.168.1.5 / 3442 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    07:32:14.671 AuthMgr::eek:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 192.168.1.4 tid=ac69574126 cseq=REGISTER contact=2003682@192.168.1.5 / 3442 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    07:32:07.921 AuthMgr::eek:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 192.168.1.4 tid=ac52698419 cseq=REGISTER contact=4372025@192.168.1.5 / 3440 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    07:31:46.625 AuthMgr::eek:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 192.168.1.4 tid=ac2146874981 cseq=REGISTER contact=4372065@192.168.1.5 / 3440 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    07:31:44.640 AuthMgr::eek:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 192.168.1.4 tid=ac2142493924 cseq=REGISTER contact=2003718@192.168.1.5 / 3440 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    07:31:43.750 AuthMgr::eek:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 192.168.1.4 tid=ac2140243510 cseq=REGISTER contact=2003682@192.168.1.5 / 3440 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    07:31:37.093 AuthMgr::eek:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 192.168.1.4 tid=ac2123124547 cseq=REGISTER contact=4372025@192.168.1.5 / 3438 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    07:31:15.906 AuthMgr::eek:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 192.168.1.4 tid=ac2070123590 cseq=REGISTER contact=4372065@192.168.1.5 / 3438 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    07:31:14.250 AuthMgr::eek:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 192.168.1.4 tid=ac2065991823 cseq=REGISTER contact=2003718@192.168.1.5 / 3438 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    07:31:13.218 AuthMgr::eek:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 192.168.1.4 tid=ac2063427872 cseq=REGISTER contact=2003682@192.168.1.5 / 3438 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    07:31:06.390 AuthMgr::eek:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 192.168.1.4 tid=ac2046372646 cseq=REGISTER contact=4372025@192.168.1.5 / 3436 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    07:30:45.203 AuthMgr::eek:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 192.168.1.4 tid=ac1993370666 cseq=REGISTER contact=4372065@192.168.1.5 / 3436 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    07:30:43.515 AuthMgr::eek:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 192.168.1.4 tid=ac1989176670 cseq=REGISTER contact=2003718@192.168.1.5 / 3436 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    07:30:42.406 AuthMgr::eek:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 192.168.1.4 tid=ac1986372550 cseq=REGISTER contact=2003682@192.168.1.5 / 3436 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    07:30:35.578 AuthMgr::eek:nAuthFailure [CM102001]: Authentication failed for SipReq: REGISTER 192.168.1.4 tid=ac1969302312 cseq=REGISTER contact=4372025@192.168.1.5 / 3434 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    thanks for any help
  2. rlust
    Mar 14, 2008
    6
    I am having the same issue.
    Where do you change the password and user ID in the MP-114 and 3CX?
  3. h2009
    h2009 Member
    Mar 15, 2008
    447
    have you follow the setup correctly :
    http://www.3cx.com/voip-gateways/audiocodes-mp.html
  4. rlust
    Mar 14, 2008
    6
    As a follow up to my post. I have the Mp118 working and I have the 4 analog extensions working also.
  5. ron.evan.gregorio
    Feb 23, 2012
    Can you share your configuration? Thanks
