Need help with routing of DDI
Discussion in '3CX Phone System - General' started by seanbts, Nov 8, 2010.
  1. seanbts
    Oct 12, 2010
    34
    Hi All,
    I'm setup a remote extension and have set one of our DDI to route directly to this extension number and have setup up the office hours for that extension, but no matter what , what I ring the DDI number it keeps going to the reception extension 10.
    [CM503012]: Inbound out-of-office hours rule (unnamed) for 10000 forwards to DN:10.
    I can't see were I would have set an inbound hours rule?
    Any help would be great, Thanks
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Hi, from what you are asking as it would seem, you wish to be able to route incoming calls based upon the time of day?
    If this is correct, then there is two ways of doing this.
    User Extension Level or VoIP Provider Level
    VoIP Provider Level
    Goto > Ports/Trunks Status and double click the VoIP Account in question
    uncheck the box where it says "Same as During Office Hours
    This will then give you more options,
    Office Hours, you could have calls going to the reception extension
    Outside Office Hours, you could have this set to another extension, which could be configured to call a mobile or even an external number out side of office hours.
    Extension Level
    Goto > Extension Status and select the extension you wish to apply hours rule
    Goto > Extension (Office Hours) Tab and select This Extension has Specific Office Hours
    and define the hours you wish the extension to be Available
    Now goto Forwarding Rules (Tab) and select the Out Of Office option and then you will be able to set where the call is redirected / Voice Mail - Another Extension, External Number, Mobile etc etc.
    Hope this helps.
  3. seanbts
    Oct 12, 2010
    34
    Hi Dave,
    Thanks for your reply, I'm actually looking to forward calls based on a particular DDI number. Our VOIP provider has provided us with 8 DDI Numbers, I have added these in under VOIP Provider, and then under Inbound rules, selected one of the DDI's and said to forward to a particular extension, but when I ring this DDI number it keeps been out through to the reception extension (10) .
  4. davidbenwell
    Apr 27, 2010
    704
    Ah right ok, What provider are you using? and how is this delivered to you?
  5. seanbts
    Oct 12, 2010
    34
    Provider is Blueface from Ireland, when I login to our account on line I see all 8 DDI's and they are set to ring to our main SIP account , so all DDI's ring to the same SIP account.
  6. davidbenwell
    Apr 27, 2010
    704
    Have you setup both Call Source identification and DID‟s associated with this account under > VoIP Providers and selecting the provider and then going to the two end fields?
    1. Setup your VOIP Provider 2.
    Under the main number for that VOIP Provder scroll down to "VOIP Provider > <number> > Other Options > Source Identification by DID"
    3. In this field define all the masks for all DID numbers that come in under this VOIP Provider.
    You do this using a comma separated list. I for example might have DID range allocated to me of 01695555100 to 01695555125 inclusive so this means I could define 0169555510*(this traps all 01695555100-109), 0169555511*(this traps all 01695555110-119), 01695555121, 01695555122, 01695555123, 01695555124, 01695555125(these I have to trap separately) 3CX then knows when it sees this number that it is related to this VOIP Provider. Just be a little careful as my assumption is that your VOIP provider sends the full DID in the SIP message, I have heard that some VOIP provider sometimes only send the last 6 digits etc. you will just need to check your SIP messages to be completely sure what is being sent to you.
    2. Next you have to tell 3CX where in the incoming SIP message this incoming DID number is stored so 3CX knows where to pluck it out of and check it against the DID mask. You do this in "VOIP Provider > <your VOIP provider> > DID > SIP Field > SIP Field containing DID numbers". In order to find this information you will need to set the logging level of 3CX to "Verbose" (then restart 3CX) and then call one of the DID numbers from an external phone.
  7. seanbts
    Oct 12, 2010
    34
    Hiya Dave,
    Have done what you suggested, can I send you via PM the Log file, as I don't understand it! thanks again for all your help,
  8. davidbenwell
    Apr 27, 2010
    704
    you can send the log to support@it-communicationsltd.co.uk
  9. seanbts
    Oct 12, 2010
    34
    Done! Cheers
