Solved Need help with Voice Mail
Discussion in '3CX Phone System - General' started by lreiber, Sep 17, 2017.
  1. lreiber
    Jul 29, 2016
    15
    I have a client that has the following conditions.
    When a call comes in and they are on the phone they would like to caller to get a busy signal.
    At non specific times, (when they go for a break, lunch or at the end of their day) they want calls to go to their voice mail.
    Any ideas on how to do this would be appreciated.
    Lawrence
    11,277
    360
    On the versions I've used, busy signal is not an option. If the extension is busy you can send the call somewhere, or choose to end it.To send a call somewhere automatically, you'd have to employ the extensions office hours.
    So... you have to send the call, to something that plays (where you've recorded) a busy signal, such as a voicemail box , digital receptionist or even an outside number that you know, is always busy.
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,783
    561
    Hello @lreiber
    Please navigate under extension settings / Forwarding rules and under the option "If i am busy or my phone is un-registered, forward calls to" set it to "End call"
    Make sure that the option "Accept multiple calls" is disabled. Click OK to apply the changes.
    Now when the extension is busy the caller will hear a busy tone.
    For calls to be forwarded to voicmail you can use any of the status options to forward calls anywhere you like.
  4. lreiber
    Jul 29, 2016
    15
    Thank you very much for your help. I have tried option one and it works great and I will test option 2.
    Lawrence
  5. YiannisH_3CX
    May 10, 2016
    7,783
    561
    Glad to hear this worked for you
