need one button shutdown from GUI
Discussion in 'Ideas' started by Leon Zetekoff, Jul 24, 2017.
  1. Leon Zetekoff
    Jan 21, 2017
    94
    8
    it would be nice to have a one button shutdown from the gui instead of having to shut each service down manually. that way the shutdown will be in the correct and proper order.
    Leon
  2. PhoneCH
    Mar 17, 2016
    and / or a "restart all services"-button
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,962
    180
    What happens if you hold down shift key and select all of them?
    Does it restart all in proper order, or shutdown all?
