need to be able to DISABLE/ENABLE trunks and routes
Discussion in 'Ideas' started by Leon Zetekoff, Aug 2, 2017.
need to be able to DISABLE/ENABLE trunks and routes 5 5 9votes
5/5, 9 votes
  1. Leon Zetekoff
    Jan 21, 2017
    95
    8
    Other PBXes allow you to disable/enable trunks and routes. 3CX should allow this. Deleting the trunk/route is not an option here looking for.
  2. Leon Zetekoff
    Jan 21, 2017
    95
    8
    any updates on this?
  3. Benedikt Machens
    Feb 14, 2018
    17
    There is no deactivate button, but if you go to SIP Trunks > *your Trunk* > Options > Call options and remove "Allow inbound calls" and "Allow outbound calls" the trunks stops registering.
    Thats not really deactivated but i would call it unuseable
  4. Leon Zetekoff
    Jan 21, 2017
    95
    8
    this should not be difficult to implement IMHO
  5. voiptoys
    voiptoys Member
    Feb 13, 2013
    493
    81
    You can do this with a combination of the Call Flow Designer and the Call Control API, or you could make a simple web interface to invoke the command.
