Need to create 4 digit extension in 3 digit installtion
Discussion in '3CX Phone System - General' started by masif25, May 4, 2009.
  1. masif25
    Apr 14, 2009
    Hello All,
    I install 3CX 7.1.6589 system, during installtion I check 3 digit extension length, now I need to create 4 digit extention. Kindly letme know how can i create 4 digit extension in 3 digit installed environment or vice versa.
    All yours support will be highly appreciated.
  2. alexmallia
    alexmallia New Member
    3CX Support
    Aug 4, 2008
    130
    You cannot use different number of digits then what you have set it up as.
    If you installed a 4 digit environment, you need to use 4 digits. if you installed with 3 digits, you have to use 3 digit numbers.
    regards
