Need to input number to transfer to
Discussion in 'Call Flow Designer' started by neville, Jul 1, 2017.
  1. neville
    neville New Member
    Apr 23, 2012
    194
    33
    I have a client that offers 24-hour support for emergency services. After hours, all calls transfer to the on duty persons work cellphone. This can change daily or throughout the night with no set pattern day to day.
    I can use Call Flow to transfer using day and time of day, but need a way to dial into the system and input the on call number to transfer to. This number can change at any time.
    Any suggestions or help is appreciated.
    Chuck
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,058
    75
    Hi Chuck,
    Do you need 2 callflows? One to handle inbound calls and transfer them to the desired destination depending date and time? And the other for you to configure the phone number where calls must be transferred? Is this your scenario?
    In that case, the second callflow just needs a User Input component to collect the number via DTMF, and then save that number in a database for example. Then the first callflow can take the destination number from the database.
    Kind regards.
    mortenjorge likes this.
  3. neville
    neville New Member
    Apr 23, 2012
    194
    33
    Ernesto,
    Thanks for the suggestion. I did as suggested except I used a txt file. Works great. Have a great day.
