Need to start learning 3cx
Discussion in 'Windows' started by TWC-3cx, Aug 28, 2014.
  1. TWC-3cx
    Aug 28, 2014
    14
    Greetings
    We have 3cx as our PABX software, it is all set up and working fine.
    But from time to time the staff need things changed. Which i need to work out how to do.
    Could someone point me in the right direction to start learning how to "get more" from our 3cx setup.
    Yes we could contact the people that set it up, But to be honest their quality of service is not the best, and we would rather not deal with them if we don't have to. Nor is there anyone, that we can find in our area at least, that works with the 3cx system.
    Thank you
  2. IliasL_3CX
    3CX Support
    Jun 2, 2014
    74
    Hi there,
    As a start you can take a look at the manuals of the 3CX Phone System or look at the online videos which can be found on the www.3cx.com
    1)Standalone manual: http://www.3cx.com/manual/3CXPhoneSystemManual12.pdf
    2)Cloud Server Manual: http://www.3cx.com/manual/3CXCloudServerManual12.pdf
    Regards
  3. roland_3CX
    roland_3CX Support Team
    Mar 28, 2014
    131
    7
    Hi TWC,
    For additional material you may also refer to the webinars posted online under the 3CX Academy section.
    http://www.3cx.com/3CXAcademy/Videos/Basic/
    http://www.3cx.com/3CXAcademy/Videos/Advanced/
