Neo Vortex VOIP calls connect no audio
Discussion in '3CX Phone System - General' started by netswork, Apr 13, 2011.
  1. netswork
    netswork Active Member
    Mar 11, 2011
    577
    I am new to 3cx but not new to IP telephony. I have setup my first 3cx server and using a sip trunk from Neo Vortex. My trunk shows registered and I can make calls but there is no audio in either direction. Any ideas? Im not sure where to start.
    Billy
  2. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    Common issue... They use a particular border gateway configuration. Check your router NAT configuration, that is usually the problem.
    Please turn off all SIP helpers/ALG that pertain to SIP. You can call their tech support (Stephen) and maybe if you are lucky they can help you (if they answer your call)
  3. netswork
    Mar 11, 2011
    577
    I got it to work by disabling stun and setting my IP on the advanced tab of the voip provider. Now my issues is calls work, audio both ways, but the calls disconnect at exactly 31 seconds into the call.
  4. netswork
    Mar 11, 2011
    577
    Sounds like your not a fan of the nex vortex....who is the prefered sip trunk provider?
  5. sigma1
    Nov 20, 2009
    542
    And the logs says "No RTP packets received" right?
