net2phone
Discussion in '3CX Phone System - General' started by kafsar, Mar 18, 2008.
  1. kafsar
    Mar 18, 2008
    Can I use net2phone (http://www.net2phone.com) with 3cx. it is support code?
  2. bhavank
    bhavank New Member
    Apr 24, 2007
    109
    Yes you will be able to use net2phone service with 3CX system.
  3. asfuture
    asfuture New Member
    Aug 3, 2007
    156
    he bhavank
    do you have some experiance with net2phone??? i want to use it but it doesn't work. i'm from Netherlands. maybe have you some ideas???
  4. Halea
    Halea New Member
    Jan 5, 2008
    151
    What's not working? What did you try to do so far to make it work?
    Give some more details so that someone can attempt to asist you.
    Halea
