Network configuration - IP server
Discussion in 'Windows' started by kawkaw, Jan 8, 2017.
  1. kawkaw
    Jan 8, 2017
    my public ip has changed, i already changed it in network card on ipv4 configuration, but its doesn't take effect on 3CX server.
    On 3CX Cloud PBX Manager V14, we can see the section "Network configuration" are grayed and i cant change it manuely.
    The change of ip on IPV4 windows dont have effect on 3CX server.
    How i can change ip on "Network configuration"
    #1 kawkaw, Jan 8, 2017
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,400
    535
    Hello @kawkaw
    Please note that to change the public IP of the multi-instance you need to backup all the instances, and then remove them. You can then change the public IP and restore the instances back
