network configuration
Discussion in '3CX Phone System - General' started by Anonymous, Jul 24, 2008.
  1. Anonymous
    Anonymous Guest
    Im having a problem where calls randomly have no audio. Ive checked all ports are ok in line with guide. This seems to be happening since version 6?
    anyway here are the logs
    11:17:36.968 CallCtrl::eek:nAnsweredCall [CM503002]: Call(20): Alerting sip:503@192.168.50.165:5060
    11:17:32.796 MediaServerReporting::InitEndPoint [MS003005] C:20.2: Failed to create Endpoint: (destination=192.168.50.165)
    EndPoint: ID=00000105@(LOCAL)
    LOGID=C:20.2 Status: MSEP_FAILED
    RTP:192.168.50.1:7330
    RTCP:192.168.50.1:7331
    STUN RTP:0.0.0.0:0
    STUN RTCP:0.0.0.0:0
    Coder:
    NOT SET
    101:telephony-event
    Party ptime:20
    Party RTP:0.0.0.0:0
    Party RTCP:0.0.0.0:0
    Decoders:
    [empty]
    11:17:32.781 MediaServerReporting::InitEndPoint [MS003003] C:20.2: RTCP socket 192.168.50.1:7331 binding failed with error code 10048
    11:17:32.781 MediaServerReporting::InitEndPoint [MS003002] C:20.2: RTP socket 192.168.50.1:7330 binding failed with error code 10048
    any ideas?
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,994
    304
    As you can see from the log, you have a networking/stun server/firewall problem. The IP is not being resolved of the end points.
    If you have a commercial edition with support, you can submit a support ticket....
  3. Anonymous
    Anonymous Guest
    but it seems from the IP that the problem is internal though?
  4. Anonymous
    Anonymous Guest
    so it seems that the the box running 3cx isnt allowing connections on port 7330 or 7331 which are part of the internal call range used (7000-7500) We arent running a firewall on the 3cx box though which makes this all a bit weird?
  5. Henk
    Henk Member
    Nov 13, 2007
    250
    I assume that the IP's are on the same subnet and Vlan?
    STUN is not related to firewall, it is related to NAT. So if you are able to setup a stun server you might get your VoIP network back up, there might be a NAT issue.
    H.
  6. Anonymous
    Anonymous Guest
    yes but is NAT relevant for internal connections? ie 7000 to 7500?
  7. remiw
    Mar 6, 2008
    I had the same problem.
    DNS server was also installed on the 3CX box. Following a recent Ms hotfix, DNS service changes its behaviour and take 2500 ephemeral ports at startup. (try a netstat or tcpview. You will understand)
    To resolve the problem, I have to change a registry to exclude 3CX range from the ephermeral port range :
    add 7000-7500 and 9000-9015 into HKLM/System/CCS/Services/TCPIP/Parameters/ReservedPorts
    Rémi W.
    http://www.aixagon.fr
  8. Anonymous
    Anonymous Guest
    great thanks for your help, both 3cx and my local 3cx specialist washed their hands of helping saying it was a firewall issue...
  9. Anonymous
    Anonymous Guest
    It is hard to come to a conclusion when all we have is part of a log file marinboy, hence the existence of commerical support.
  10. coertvc
    Jan 23, 2014
    26
    not supported in 2008 r2 server; FYI
    http://support.microsoft.com/kb/2665809
