Network setup, two nics, 3CX tunnel problem
Discussion in '3CX Phone System - General' started by Hermos, Jun 7, 2017.
  1. Hermos
    Jun 7, 2017
    we have problems to setup our 3CX environment.
    Our current setup:
    • LAN: 172.21.3.0
    • WAN: 192.168.1.0
    • 3CX has two nics, one for LAN (172.21.3.1) and one for WAN (192.168.1.1)
    • FQDN is defined
    • Local DNS resolves FQDN to 172.21.3.1
    • Router (192.168.1.254) is forwarding all relevant ports to 192.168.1.1; 3CX firewall check is OK.
    We'd like to use 3CX clients and 3CX tunnel for internal and external usage.
    But: We can't call internal extensions when connected via tunnel - if we connect via SIP from external it works. Tunnel to tunnel doesn't work, too.
    Any hints?
    Thanks in advance,
    Michael
  2. Panayiotis_3CX
    Panayiotis_3CX Support Team
    Apr 26, 2017
    165
    7
    Hello @Hermos,
    Can you please explain from which network you're trying to connect through the tunnel?
    Also, from which network is the server routed?
  3. Hermos
    Jun 7, 2017
    Hello panayiotis_3CX,
    thanks for your reply.
    To make these things more clear we made a reinstall with only one NIC (192.168.1.1) which is behind our WAN router.
    We added two extensions 301 and 302 and connect from outside via 3CX tunnel. Both clients have established connections using port 5001 and 5090.
    302 can call 301 BUT 301 cannot call 302:
    08.06.2017 10:54:21 - Leg L:27.1[Extn:301] is terminated: Cause: BYE from PBX
    08.06.2017 10:54:21 - [CM503020]: Call(C:27): Normal call termination. Call originator: Extn:301. Reason: Not found
    08.06.2017 10:54:21 - Leg L:27.2[Extn:302] is terminated: Cause: 404 Not Found/INVITE from 127.0.0.1:5080
    08.06.2017 10:54:21 - [Flow] No office hours set, office hours assumed
    08.06.2017 10:54:21 - L:27.1[Extn:301] failed to reach Extn:302, reason Not Found
    08.06.2017 10:54:21 - Call to T:Extn:302@[Dev:sip:302@172.26.9.110:50195;transport=TCP;rinstance=1-5f1a6db50624403687a76b772cbaff28;ob] from L:27.1[Extn:301] failed, cause: Cause: 404 Not Found/INVITE from 127.0.0.1:5080
    08.06.2017 10:54:21 - [CM503003]: Call(C:27): Call to <sip:302@***FQDN***:5060> has failed; Cause: 404 Not Found/INVITE from 127.0.0.1:5080
    08.06.2017 10:54:20 - [CM503025]: Call(C:27): Calling T:Extn:302@[Dev:sip:302@172.26.9.110:50195;transport=TCP;rinstance=1-5f1a6db50624403687a76b772cbaff28;ob] for L:27.1[Extn:301]
    08.06.2017 10:54:20 - [CM503027]: Call(C:27): From: Extn:301 ("User 301" <sip:301@***FQDN***:5060>) to T:Extn:302@[Dev:sip:302@172.26.9.110:50195;transport=TCP;rinstance=1-5f1a6db50624403687a76b772cbaff28;ob]
    08.06.2017 10:54:20 - [CM503004]: Call(C:27): Route 1: from L:27.1[Extn:301] to T:Extn:302@[Dev:sip:302@172.26.9.110:50195;transport=TCP;rinstance=1-5f1a6db50624403687a76b772cbaff28;ob]
    08.06.2017 10:54:20 - [Flow] No office hours set, office hours assumed
    08.06.2017 10:54:20 - [Flow] Call(C:27): has built target endpoint: Extn:302 for call from L:27.1[Extn:301]
    08.06.2017 10:54:20 - [Flow] Target endpoint for 302 is Extn:302
    08.06.2017 10:54:20 - [CM503010]: Call(C:27): Making route(s) from Extn:301 to <sip:302@***FQDN***:5060>
    08.06.2017 10:54:20 - [CM505001]: Endpoint Extn:301: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone for Windows 15.5.1694.0] PBX contact: [sip:301@127.0.0.1:5060]
  4. Panayiotis_3CX
    Apr 26, 2017
    165
    7
    Hello @Hermos,
    Do you have the ability to open a ticket in our Support Portal?
