New 3CX Assistant version 8.11114
Discussion in '3CX Phone System - General' started by converted, Jul 18, 2012.
  1. converted
    Feb 14, 2012
    Hi, does anyone know if this new version keeps logs of chat messages?
    I know the older version didn't but i'm looking for a solution that does.
    Any help appreciated
    Regards
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
    3cx Assistant v8 is not new. You should look at upgrading to v11. 3cx Assistant has been replaced with MyPhone.
  3. converted
    Feb 14, 2012
    Thanks i see , its the same as before almost
