New 3CXPhone for 3CX Phone System
Discussion in 'Android' started by danhriscanu, Feb 22, 2013.
  1. danhriscanu
    danhriscanu New Member
    Nov 29, 2011
    232
    3CXPhone for 3CX Phone System, it's a new Android SIP client that has been designed specifically for use with 3CX Phone System 11 and up! 3CXPhone integrates seamlessly with 3CX and allows you to make and receive office calls on your Android smartphone from anywhere using 3G and WiFi. Make savings on your telecommunications costs by making internal office calls free of charge. Keep your mobile number confidential by using the office caller ID.
    3CXPhone for 3CX Phone System features include:
    Make and receive calls from your extension via 3CX Phone System 11
    Use your work number rather than your personal mobile number – calls made to your desk phone will ring on your smartphone
    Use company infrastructure to save on call costs – make free inter-office calls from wherever you are, rather than via the mobile network
    Seamless out of office or in office detection
    Integrated 3CX Tunnel bypasses remote firewall or provider issues
    Transfer and hold calls
    Easily change your status to In or Out of the Office
    Provision extension details via email
    The new 3CXPhone requires Android 2.3 and up and 3CX Phone System 11 and up. 3CXPhone is free to use for all 3CX Phone System 11 users and is available to download from Google Play.
    https://play.google.com/store/apps/details?id=com.tcx.sipphone
