- Joined
- Dec 12, 2008
- Messages
- 2,724
- Reaction score
- 924
The new 1.1.4 is available on App Store. IMPORTANT: Tunnel feature is NOT available! Here is the changelog:
NEW
- Support for iOS 5 (Notification Center must be enabled manually)
- Toggle for In/Out of Office settings
- Start-up screen
- Renewed SIP engine for better handling
- Improved audio handling and routing
- iPod playback stops and re-starts after a call
- Support for foreign characters
- Perform re-register in case network state changes (WiFi->WiFi or Wifi<->3G)
- Notification when phone becomes unregistered
- Notification Index for missed calls
- Profile Name will be provisioned (EXT@autoprov)
- Profile Display Name will be provisioned
- FromisplayName will be shown when present
- Recording exchange via iTunes
- GSM call handling
- Echo Cancellation
Fixed
- Incorrect handling of non-standard 5060 PBX SIP ports
- Unregister when application is terminated by iPhone (on multitasking devices)
- Improved multitasking (no longer based on audio)
- "Audio-friendly" with other applications
- Key-Pad-Sounds are routed to Earpiece after first call
- Ringing-Sounds are routed to Earpiece after first call
- Application hangs at start up (Stun resolving issue)
- Fixed PBX non-standard SIP port provisioning
- TCP port will be released correctly
- Removed duplicate INVITE when make/hold/retrieve calls
- Removed a "ghost" screen snapshot appearing for a short time when app starts
- Proximity sensor only handled during a call
NEW
- Start-up screen
- GSM call handling
- Echo Cancellation
Fixed
