new active calls utility for 3cx
Discussion in '3CX Phone System - General' started by asfuture, Aug 12, 2008.
  1. asfuture
    asfuture New Member
    Aug 3, 2007
    156
    HI Matt
    wonderful. how did you do???
    I'm very curios, and... dw?? where??
  2. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello Matt,
    very nice from you
  3. ess
    ess New Member
    Jun 8, 2007
    133
    matt,
    Thanks for the contribution to 3cx development. Oh wait, you've contributed 10,000 other ideas, reports, concerns, and fixes to aid 3cx development already :lol: .
  4. cimesrl
    Jun 26, 2008
    8
    Hi matt,
    This sound very interesting and maybe is what I seek.
    I'd like to reach the same results from my .net application for example create a panel that show me in real time the lines and extensions status, as shown in the "line status" page of 3CX management console.
    Have you wrote something similar? Can you give me some suggestion of what can I do?
    very thanks,
    Francesco
  5. cimesrl
    Jun 26, 2008
    8
    Can you tell me something more?
    Are you able to connect to 3CX database and read line status using microsoft Access?
    Where is the database and how can I connect to it?
    Thanks a lot,
    Francesco
  6. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello Matt,
    I got your software
    Thank you very much
    I see you are good in access
    so can you make a patch to export the records to simple database file in dos database format
    (database IV,3,or foxbase)
    I need this to read it from my old dos software
    Thank you
  7. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello Matt,
    I'm in the other half of the world
    we at mednight now
    so The internet the best way to talk
    Thank you
  8. cimesrl
    Jun 26, 2008
    8
    Hi matt,
    I sent you a private message with my email address to get your utility. Is the right procedure?
    Thanks,
    Francesco
  9. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello Matt,
    what I'm asked about
    it's small patch to export the new records into database 4 (dos)
    a lot of community users need to test it
    It's easy to open the database file in access
    but I need to use it in dos format to integrate it into old dos software
  10. cimesrl
    Jun 26, 2008
    8
    Hi Matt,
    I got your Access file.
    Very Thanks.
    Francesco
  11. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello Matt,
    I think the patch file is easier in compare with your utillity
    it will help us (me ,Francesco and others) to integrate our software to 3CX data
  12. amygoda
    amygoda Member
    Sep 18, 2006
    436
    it's a file run to export the new records from access file to database 4 file
    to make the database 4 file uptodate with access file
  13. amygoda
    amygoda Member
    Sep 18, 2006
    436
  14. SWB
    SWB New Member
    Mar 26, 2008
    136
    Hey matt submitted my request via your link.
    Also I noticed "Partner" is spelled wrong in "I am a 3CX Parter or Reseller" check box heading :lol: :mrgreen:
    Looking forward to finally trying this out =D
    Thanks!
  15. dws
    dws
    Aug 7, 2008
    20
    Matt
    Thanks for the addon received the file.
    What I would like to know, especially for call centers, will this be able to show call records of how many calls and the length of the call in a call report?
    For example a call center of 20 employees want to see how many calls they are actually calling thru out the day, but dont need to see all the inbetween, will this tool pull that information?
    IE: EXT Calls Total Calls
    Tom
  16. SWB
    SWB New Member
    Mar 26, 2008
    136
    Nice little app matt...thanks!
    Had to change font sizes in the operator panel though because they were teeny tiny - I could barely read them. But I like the panel.
  17. radcomp
    Aug 21, 2008
    35
    Love the program i would love to access this via my webhosting server is it possible is there any easy way to set this up as i want to be able to view this over three offices
    cheers
    Josh
  18. Manikandan
    Sep 27, 2008
    Thanks for the MDB . I want a remote log . how can i change 127.0.0.1:5480 ???
    Mani
  19. Manikandan
    Sep 27, 2008
    Hi Matt
    I am not able to see the TXT file along with the Zip folder !
    with regards
    Mani :roll:
  20. Discovery Technology
    Apr 19, 2008
    278
    Matt,
    Are you seeing any info coming from the 3CX server on parked calls? (you mentioned that you are seeing a "LOT" of info coming from the server - it would be interesting if you could expand on that to assess what is possible)
    I thought you'd like this question from our chats in the other forums...
    Thanks, Brendan
