New AD Server, Small Windows client issue
Discussion in '3CX Phone System - General' started by chaznsc, Feb 2, 2016.
  1. chaznsc
    Jan 22, 2016
    10
    We successfully installed a new server this week via a consultant. Everything works EXCEPT the Windows client phones will not display status or the phone book. Calls still work however. I have attached the little warning we get on the client phone.
    11,293
    361
    It sound as if the port, used by your system for presence, has not been opened (forwarded) at the 3CX PBX end router/firewall.
    http://www.3cx.com/docs/3cx-phone-system-v14-ports/
    Are you using other devices (remotely), for which this is working properly? (Is it only the Windows phones having this problem?)
  3. chaznsc
    Jan 22, 2016
    10
    The ports on the firewall are open. The only thing different are the local domain name has changed and the server has a different IP address.
  4. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,088
    65
    Send each user the welcome email and then provision the softphone with the configuration file that came embedded in the email.
  5. chaznsc
    Jan 22, 2016
    10
    I tried this on my windows box and now my soft phone wont even connect.
  6. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,387
    88
    If you have changed the Internal/External FQDN and/or Internal/External IP of the 3CX Phone System post-installation, the Welcome Email will contain the incorrect information so it will not work.
    If this is the case, make a Full Backup, uninstall, re-install, then restore your Full Backup, then try re-sending the Welcome Email again.
