New BUG's report
Discussion in 'CRM / Helpdesk / App Integration' started by hpioteput, Dec 20, 2009.
  1. hpioteput
    Nov 1, 2009
    37
    Hi again,
    1. Record component: during prompt playing hang up the phone -> instead of disconnect handler flow got error handler with ecmascript error.
    2. Using external code execution, COM:
    configured to send to COM 2 parameters, for example:
    aCallerId : session.ani
    aIvrId : session.dnis
    result: COM receive inverted order of parameters:
    aCallerId : session.dnis
    aIvrId : session.ani
    It is appalling to think if count of parameters would be more than 3-10...
    Please advise.
    3cx Free Testers Team 8)
  2. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Do you have an ecmascript error in your disconnect handler?
    Perhaps it correctly went to your disconnect handler, but then you had the ecmascript error in the disconnect handler so it then correctly jumped to the error hander.
    What components do you have in your disconnect handler?
  3. hpioteput
    Nov 1, 2009
    37
    Hi SWSDEV,
    Error without description.
    My simple test IVR:
    externalCodeExecutionComponent1 - JS (generate file name)
    variable assignment - variable "project$.WavFileName" = CONCATENATE(externalCodeExecutionComponent1.ReturnValue,'_from_',session.ani,'_to_',session.dnis,'.wav')
    result in "project$.WavFileName" I get "2009_11_6_9_2_55_from_100_to_851.wav"
    Audio recorded eMailSenderComponent1 that configured to send attach "project$.WavFileName"
    All work fine, email received with voicemail etc. BUT if hang up the phone when recording component prompt played receive error.semantic.ecmascript without error description.
  4. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Can you post your project zipped, removing any sensitive data like passwords, etc. if you have?
    As SWSDEV said, maybe there is a problem in the e-mail sender component in the disconnect handler. You can see a detailed description about the ecmascript error in the log file located in %ALLUSERSPROFILE%\Application Data\3CX\Data\Logs\3CXIvrServer.log. Can you post here the error you see in that file?
    In regards to the second problem reported, it is very strange because the VAD has been tested with COM components and multiple parameters and works here. How are you creating your COM component? Is it a Visual Basic 6 ActiveX, a C++ COM?
    Thanks.
  5. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Some value in your disconnect handler must not be quoted when it should be, or some value is not returning what you expect during runtime that may seem ok at design time.
  6. hpioteput
    Nov 1, 2009
    37
    I disable all components in disconnect handler. Tested this in callflow and receive same result. You can test this situation "1. Record component".
    Create record component and setup prompt for this component. Build, deploy, during prompt playing hang up the phone.
  7. VAD_Support
    Aug 6, 2009
    690
    I will check this and let you know. Thanks.
