New error
Discussion in '3CX Phone System - General' started by dave151, Dec 12, 2007.
  1. dave151
    Jun 13, 2007
    6
    I've started getting this error after upgrading to Ver 5
    [CM100002]: *!* Exception detected: ParseBuffer.cxx:948, Parse failed unexpected eof in context: From
  2. AldoLinares
    AldoLinares New Member
    Nov 12, 2007
    135
    Do you have the complete log?
    Or maybe what where you trying to do when this happen, what devices??
  3. dave151
    Jun 13, 2007
    6
    it pops up every 45 seconds. doesn't matter if i'm on the phone or not.
  4. silentfun
    silentfun Member
    Dec 11, 2006
    364
    if you have not so much lines and extensions try clean setup
    of if that is to much work try at least backup and restore after clean install.
    Andy
