Solved New Final Release Upgrade to 15.5.1694.0 fails error log
Discussion in '3CX Phone System - General' started by computatech, Jun 7, 2017.
  1. computatech
    Oct 21, 2016
    20
    When i run the upgrade thats just been realised i get an error when trying to upgrade it (debian 8)
    Upgrading from 15.0.62928.5 to 15.5.1694.0
    error log file
    Reading package lists...
    Building dependency tree...
    Reading state information...
    The following extra packages will be installed:
    libcairo2 libexif12 libgdiplus libgif4 libpixman-1-0 libxcb-render0
    libxcb-shm0 libxrender1
    The following NEW packages will be installed:
    The following packages will be upgraded:
    3cxpbx
    1 upgraded, 8 newly installed, 0 to remove and 0 not upgraded.
    Need to get 746 kB/82.0 MB of archives.
    After this operation, 15.3 MB of additional disk space will be used.
    Err http://httpredir.debian.org/debian/ jessie/main libcairo2 amd64 1.14.0-2.1+deb8u1
    404 Not Found [IP: 151.101.60.204 80]
    E: Failed to fetch http://httpredir.debian.org/debian/pool/main/c/cairo/libcairo2_1.14.0-2.1+deb8u1_amd64.deb 404 Not Found [IP: 151.101.60.204 80]
    E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
    Rollback to 15.0.62928.5...
    3cxpbx is already the newest version.
    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    Anyone else getting this??
  2. StefanW
    Jun 2, 2009
    1,199
    79
    the error is not 3CX Update related but breaks the hold linux update process.
    It can no locate a debian update.
    have you tried to run from root
    apt-get update --fix-missing as suggested
  3. computatech
    Oct 21, 2016
    20
    i am guessing the 3cx script will be triggering the linux operating system update which fails and in turn doesn't allow the 3cx upgrade to happen i would think many other people will see this error soon as they start upgrading.
    I will try to log into root and do a manual install, will see if this resolves the issue.
  4. StefanW
    Jun 2, 2009
    1,199
    79
    from ssh try
    apt-get update
    apt-get upgrade
  5. computatech
    Oct 21, 2016
    20
    Ok good news
    From SSH i ran as suggested
    apt-get update
    apt-get upgrade
    and then done the upgrade from 3cx uprade web page and its successfully upgraded 15.5 happy days :)
    JackH likes this.
