New Grandstrem Firmware Released
Discussion in '3CX Phone System - General' started by ktikoft, Dec 5, 2007.
  1. ktikoft
    Jun 22, 2007
    59
    Hi all just to let you know Grandstream have released an Upgraded Firmware release to their website
    http://www.grandstream.com/firmware.html
  2. AldoLinares
    AldoLinares New Member
    Nov 12, 2007
    135
    Do you now the new features?
  3. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    comparing to their latest release you can at least Dial onhook and MWI now working correctly
    Cheers
  4. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Also Found this on http://www.voip-info.org
    Build 1.1.5.15 (11/19/2007)
    • Fixed GXP display "Not Registered" for accounts that does not require registration
    • Fixed GXP1200 LCD display corrupted
    • Fixed AEC divergence during call waiting tone
    • Fixed default router gets changed under static IP mode incorrectly
    • Fixed GXP1200/GXP2010 out-of-memory problem/idle screen crash. Note: A hard power-cycle is REQUIRED after the new firmware is loaded.
    • Fixed softkey problem with onhook dial
    • Fixed softkey problem with direct IP call
    • Fixed GXP2010 color LED blinking issue
    • Fixed GXP2000 EXT issue
    • Fixed BT200 redial problem after deleting called log. Fixed GXP missed call cannot be removed by LEFT key completely
    • Added support for padding bit in RTP
    • Fixed GXP2010/GXP2020 LCD backlight does not function correctly
    • Fixed BT200 change codec from UI MENU will also change Voice Frames Per TX incorrectly
    CHeers
  5. silentfun
    silentfun Member
    Dec 11, 2006
    364
    i use this FW with GXP-2020 but there i have some problems.
    -freezing after different times when i use the web interface
    -no reregistering at 3CX BPX
    -sometimes freezing when i use cenferencing features
    -no "do not disturb status in idle screen
    -no xml applications running from softkey
    Andy
