ZenMasta
Forum User
- Joined
- Mar 10, 2010
- Messages
- 215
- Reaction score
- 7
Just installed v9. And I'm trying to to setup a pots line and 1 softphone.
Problem:
I'm using a Grandstream GXW-4104 gateway. I have a single line connected into channel 1 on that device. I was trying to follow this tutorial http:/ /www.3cx.com/voip-gateways/Grandstream-GXW-41044108/ NO LONGER AVAILABLE
Gateway:
http://buggyonpurpose.com/random/SS-201 ... .31.20.png Status Tab
http://buggyonpurpose.com/random/SS-201 ... .35.31.png Channels Tab
http://buggyonpurpose.com/random/SS-201 ... .36.42.png Dial Plan
http://buggyonpurpose.com/random/SS-201 ... .37.11.png Profile 1
3CX:
http://buggyonpurpose.com/random/SS-201 ... .39.18.png Trunk Status
http://buggyonpurpose.com/random/SS-201 ... .41.02.png Extension Status
Softphone:
http://buggyonpurpose.com/random/3CXPho ... .54.07.png Forbidden
Server Activity Log:
I only see server activity when trying to dial from the soft phone. If I try to call the line I don't see any activity.
Thanks.
Problem:
- When I call in (from my cell etc) it rings once or twice and then all I hear is a dial tone sound.
- I can't dial anything without a forbidden message and a couple of beeps. Doesn't matter if it is an extension or an outside number.
Gateway:
3CX:
Softphone:
Code:
12:00:17.375 Requests rate from IP 127.0.0.1:1149 is too high! Blacklisted for 334 seconds
12:00:17.375 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
INVITE sip:*999@localhost:5060 SIP/2.0
Via: SIP/2.0/UDP 127.0.0.1:1149;branch=z9hG4bK-d8754z-5a61e377cc480454-1---d8754z-;rport=1149
Max-Forwards: 70
Contact: <sip:[email protected]:1149;rinstance=157924ea8ffde435>
To: <sip:*999@localhost:5060>
Call-ID: ODY3Y2Y0NGM4YzQ4NmI2M2Y2OGQ0MTg3ZGU5NzhlMmE.
CSeq: 1 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
Supported: replaces
User-Agent: 3CXPhone 4.0.13679.0
Content-Length: 0
12:00:17.375 [CM302001]: Authorization system can not identify source of: SipReq: INVITE *999@localhost:5060 tid=5a61e377cc480454 cseq=INVITE [email protected]:1149 / 1 from(wire)
11:59:07.265 [CM306003]: SIP IP:port mapping (99.59.241.22:57100) resolved by STUN server 96.9.132.83:3478 differs from the one (99.59.241.22:64404 resolved by STUN server 96.9.132.79
11:59:07.015 [CM506003]: Resolved SIP external IP:port has changed to (99.59.241.22:57100) on Transport 192.168.13.163:5060
11:58:11.343 [CM302001]: Authorization system can not identify source of: SipReq: SUBSCRIBE 100@localhost:5060 tid=845f13688104353b cseq=SUBSCRIBE [email protected]:1149 / 1 from(wire)
11:54:06.234 Requests rate from IP 127.0.0.1:4972 is too high! Blacklisted for 334 seconds
Max-Forwards: 70
Call-ID: MjU2OGRhYmUwYjVjMGY0NTZiMDA4OTJkOTIxMmE5NDY.
11:54:03.125 [CM302001]: Authorization system can not identify source of: SipReq: SUBSCRIBE 100@localhost:5060 tid=6f780c45a6171502 cseq=SUBSCRIBE [email protected]:4972 / 1 from(wire)
11:52:07.218 Requests rate from IP 127.0.0.1:4045 is too high! Blacklisted for 334 seconds
INVITE sip:2@localhost:5060 SIP/2.0
Max-Forwards: 70
To: <sip:2@localhost:5060>
Thanks.
