new install 3cx version 7 with Cassini no management console
Discussion in '3CX Phone System - General' started by nanao, Dec 11, 2008.
  1. nanao
    Dec 11, 2008
    hello,
    just ran a clean/new install 3cx version 7 with Cassini and when completed (no error) then try running the management console http://localhost:5481/ nothing came up; looks like Cassini webserver is not running.
    this is on a windows xp pro box.
    some help please, how to run Cassini to allow access to Management Console.
    thx!!!
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,558
    118
    Try re-installing and Completing the Wizard Correctly with your system's IP.
    If you already did that, when you re-install try and check if all the 3CX Services are running. You can find them in your Control Panel > Administrative tools > Services
    http://localhost:5481/MainForm.wgx or http://localhost:5481 should work
