New Install, phones can't find boot server
Discussion in '3CX Phone System - General' started by Cory Trapp, Aug 2, 2010.
  1. Cory Trapp
    Aug 2, 2010
    I've just downloaded the software off the Web and installed on a Windows Server 2003. Default install using Abyss as the Web Server. System seems to start well enough, console loads. Polycom SP 330 at factory defaults reports unable to locate boot server. DHCP Option 66 is set to http://192.168.x.x/provisioning . I can't find the config files on the system, I don't know how to check if the url is correct. Ideas?
    Cory Trapp
    Gunsite Academy, Inc.
    (928) 636 4565
  2. Cory Trapp
    Aug 2, 2010
    I've located the cfg files, the Abyss path looks correct in the Abyss conf file. Is there some way to test the cfg url without the phone?
  3. carolinainnovative
    May 4, 2009
    369
    5
    Cory - glad you found the files.
    With Abyss - use http://ip.address:5481/provisioning/
    I didn't see the port number in your original post...
    to try and download the files directly, use that url with the filename appended.
  4. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,406
    81
    With IIS, the path should be: 192.168.1.1/management/provisioning
    With Abyss it changes to: 192.168.1.1:5481/provisioning
  5. carolinainnovative
    May 4, 2009
    369
    5
    NOT that it should matter - but the blog entry on this does list the trailing / in the url for polycom.
  6. Cory Trapp
    Aug 2, 2010
    That's it, the missing :5481. Seems the docs are not quite up to date, I did not locate the blog entry. Thanks! I'll give you a call in a few days, if this tests out like it should, we'll need a commercial lic and a few more phones.
