gschwab
- Joined
- Mar 21, 2012
- Messages
- 131
- Reaction score
- 0
Hello al,
I'm going to install 3CX in our offices but have a couple of questions just in case i'm missing something.
We have six PSTN lines currently connected to an old Nortel system with six extensions so to get started I'm going to keep my PSTN lines with Verizon just as they are now.W e also have two alarm systems with dialers in them connected to two of the lines.
Am I correct in thinking that all I basically need to do is install the software, install a gateway to connect the pstn lines to the network, install an ATA to connect the two alarm dialers to the network, add some IP phones and of course correctly configure all of the above? I will use only 3CX supported equipment.
Thanks,
George
Thanks,
George
