New Installation Suggestions & Setup
Discussion in '3CX Phone System - General' started by Rel82me1, Feb 17, 2012.
  1. Rel82me1
    Feb 17, 2012
    G'day mates,
    Looking to setup a new 3xc system for a small office with 4 CISCO SPA504G and a 3CX 8 SC, basic 3XC server edition. As a result, just wondering if anyone has any suggestions for a best practice setup? We currently have a cable modem and 4 computers on a small network.
    Any suggestions in terms of routing devices and general hardware setup would be greate! Thank you
  2. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    Will you be connecting to the pstn via VoIP or analaog lines? How much bandwidth do you currently have?
    In our office we're using sip trunks and a netgear n900 router, with a Netgear Smart switch. the pbx is on a simple desktop using Windows 07, we've also used XP. no issues with either as this is a pretty small deployment similar to yours.
