New PBX Install Won't Register Extensions
Discussion in '3CX Phone System - General' started by calsmiller, Nov 27, 2011.
  1. calsmiller
    Nov 27, 2011
    9
    Hi, I am new to 3CX, but currently successfully operate an asterisk based system and have successfully implemented our SIP carrier and softphones (linksys) on that platform, we also use X-lite and have had great luck. We need an easier to manage system so I was interested in this one. So, here's where we are:
    1. New Instance of Windows Server 2008 R2 installed in a data center with 10MB connection and all appropriate (I think) firewall ports open
    2. clean 3CX install
    3. SIP provider is registered and DID is accepting calls to 3CX, I can route to specific functions and it seems to be working.
    4. None of our extensions, softphones or phones will register. I even tried the 3CX iphone app....
    Anybody have any ideas ? Happy to share our results here.
    Thanks !
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Open the extensions and select the “Other” Tab and at the bottom, you should see a tick box with “Disallow use of extension outside the Lan” untick this box and apply. Reboot your phone and should now work
  3. calsmiller
    Nov 27, 2011
    9
    That was it ! Thanks so much. I was going nuts looking at firewalls, other settings. Thanks again.
  4. davidbenwell
    Apr 27, 2010
    704
    Excellent, no worries. Enjoy
