New Phone Templates Not Appearing
Discussion in '3CX Phone System - General' started by aklawrence, Aug 26, 2013.
  1. aklawrence
    Dec 8, 2011
    13
    I have version 11 SP4 and I cannot add new provisioning templates. If I modify an existing template through the Management Console and Save As another file, it does not show up in the dropdown list. If I manually create a .ph.xml file and place it in the C:\ProgramData\3CX\Data\Http\Templates\phones directory with the other templates, it does not show up from the dropdown list inside the console.
    I tried both modifying and creating new files and restarted the system but do not see the new templates. Anything else I can check?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,586
    309
    You need to change the information at the top of the provision file...
    I think it takes the name or the model field.
  3. aklawrence
    Dec 8, 2011
    13
    That was exactly what it was.
    Thank you
