NEW PROBLEM FOUND
Discussion in '3CX Phone System - General' started by kirimis, Dec 12, 2007.
  1. kirimis
    Oct 16, 2007
    43
    i discovered in version 3,i do not know if exists in 5, that you can not insert 2 different voip provider with the same Authentication ID. it comes out a masage "Object duplication error". And i cannot understand why. I want to have 2 voip lines from different voip providers but with the same registration, why is that not possible? can somebody help?
  2. giovanni0826
    Apr 6, 2007
    53
    download 3.1 its corrected in that version.
