New release soon?
Discussion in 'CRM / Helpdesk / App Integration' started by millsey, Feb 13, 2013.
  1. millsey
    millsey New Member
    Dec 21, 2011
    190
    Is there likely to be a new release soon? We still struggle to develop flows in the VAD due to the various required workarounds and I am about to do a large rewrite of all our customer facing flows...
    Millsey
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Hi Millsey,
    We continually work on fixes and new features, and regularly release new versions, but right now I don't know when we'll make a new release. If you're doing the rewrite because of the user input buffer problem, I would suggest you to go ahead, because that problem has not an easy solution from the VAD, it requires changes to the underlying 3CX IVR and I'm not sure when it will be addressed.
    Regards,
  3. millsey
    millsey New Member
    Dec 21, 2011
    190
    Ok thank you for responding.
    Millsey
