Solved New Setup PBX express on cloud welcome mail not been sent
Discussion in '3CX Phone System - General' started by Arunesh Dutta, Sep 9, 2017.
  1. Arunesh Dutta
    Sep 9, 2017
    36
    Hello all
    I have just installed PBX express on google cloud.While installing I entered my SMTP details and and tested it showed fine and sent me a mail,but after login to management console if I try sending welcome email after selecting any of extension the same is not getting delivered.Even in Settings>Mail I am seeing same settings but while I try to press Test button nothing happens.Kindly guide me how to fix this issue.Thanks once again
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,448
    541
  3. Arunesh Dutta
    Sep 9, 2017
    36
    Thanks a lot,I configured it with other mail service from my domain it works fine now
  4. YiannisH_3CX
    May 10, 2016
    7,448
    541
    Glad i could help and thank you for sharing your solution
