New Update, New Features: 3CX WebMeeting
Discussion in '3CX Phone System - General' started by Bianca, Apr 12, 2018.
  1. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,559
    118
    jed likes this.
  2. Marari
    Marari New Member
    Sep 16, 2007
    230
    50
    Nice!
  3. jed
    jed New Member
    Feb 1, 2010
    153
    48
    Hi Leonidas..
    Would it be possible for you to change the default Headset/Speaker to the Standard comminication unit?
    We recieve complains, that when the users (using the 3CX SoftPhone) is attending a Webmeeting, they have to change theier settings each time (they have to change the Standard Communication unit to the standard unit), to be able to use their headset - or do you have a little trick so we as a standard can use the Standard Communication unit when using Webmeeting?
    The issue is that people forget to set back the Speaker to Standard, and then they dont hear the 3CX SoftPhone ringing.
    Thank you.
