New User Evaluating System
Discussion in '3CX Phone System - General' started by neilhooper, Jul 12, 2014.
  1. neilhooper
    Jul 12, 2014
    16
    3CXv12
    Does anybody know it the option to press * to go to the operator when leaving a voicemail can be removed and can the duration of a voice mail be limited.
    We are a very small company and have no need for the 'operator'
    Thanks in advance.
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi Neil,
    This option cannot be disabled, but you could customize prompt RECYAMSG (record_your_message.wav) to not state the option. Then have a dummy operator extension with terminate call in all forwarding rules cases, just in case one would push * anyway.
    Voicemail max duration can be adjusted following this article : http://www.3cx.com/blog/docs/maximum-duration-voicemail/
  3. neilhooper
    Jul 12, 2014
    16
    Thanks for that.
    I've edited a copy of the file and cut the last part off so the voice used remains the same as all the others.
    I didn't realise that the time limit was already set to 120 seconds which is fine, our last system was 270 seconds and that's a lot of silence to listen to !!!!
