- Joined
- Dec 1, 2009
- Messages
- 3
- Reaction score
- 0
I am getting started with 3CX and VOIP in general and have a couple of questions...
I am using a VOIP provider in the UK called Soho66 (http://www.soho66.co.uk). They recommended the 3CX softphone which I have installed on a couple of PCs. Next step is integration with Salesforce...
Question is whether I need anything more to do this? I have installed the 3CX Assistant and configured it with my Soho66 VOIP credentials but it cannot connect. I get the following message:
3CX Assistant
Logging in timed out. Check server settings.
OK
Should this work or do I need to be using 3CX PBX?
I am a bit confused but really want to find a simple solution that allows me to dial numbers out of my web browser.
Any help would be much appreciated...
thanks,
Fergus
3CX Assistant
OK
thanks,
Fergus
