New User with questions
Discussion in '3CX Phone System - General' started by jmorley, Sep 29, 2010.
  1. jmorley
    Sep 29, 2010
    14
    I have got 3cx set up with 2 computers using the 3cx softphone and 2 extensions. I would like to set up a cisco 7970(if possible) on my laptop. I been reading and it seems Cisco is not very supported with 3cx. If i were to purchase a 7970 ip phone from Cisco, would 3cx support it.
    If not, I plan to go with a CISCO SPA XXX phone, I need to understand a few things. Are the SPA plug and play, just get the power adapter, use a Ethernet cord into the computer and plug into my router and set it up? Am i right? I don't have any pbx hardware only the 3cx software.
    Thank you
    Jordan
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,400
    79
    My suggestion is to not go for the 7970... It is NOT "Plug and Play". You would probably end up giving it away for free after failing to configure it, that's how unfriendly it is.
    Go to a SPA XXX series which is pretty much plug and play as you say. After connecting the phone's wires, you just need to change a couple of settings in the phone it's self / adding the Server IP so the phone knows where to connect and that's it.
  3. Fatboy40
    Fatboy40 New Member
    Aug 2, 2010
    170
    Leonidas,
    You may not want to answer this but what's your opinion on the Linksys SPA962 ?. To all intents and purposes is it just a rebranded Cisco SPA525G ? (I think it may be vice versa though in the the Linksys came first ?).
    Without knowing more it looks like it is, and is a heck of a lot cheaper.
    Thanks.
  4. jmorley
    Sep 29, 2010
    14
    For the SPA series, I am just a bit confused on POE, power over Ethernet. Now I know what Ethernet is, my router uses Ethernet cables for my pc's. Now for the SPA525 (or similar), I just need to understand. I buy the phone, plug the Ethernet cable into my computer or my router, and set it up through 3cx and callcentric (what carrier i plan to use) and I'm good to go? Thanks, I think i got almost everything ready to purchase the phone, just need to know where to put the cables ha ha.
  5. Fatboy40
    Fatboy40 New Member
    Aug 2, 2010
    170
    PoE injects a small current into the Ethernet cable, enough to power say a phone or a WiFi access point. The chances of your router providing ports with PoE though is near enough zero, so to quote the Cisco website...
    The power supply for the SPA525G is sold separately
  6. LeonidasG
    Nov 19, 2008
    1,400
    79
    You can either connect your phones with the Power Cable that comes with them so they power up / turn on and connect them to your routers, OR you can use power over ethernet.
    For power over ethernet you would need a router that actually supports Power Over Ethernet. You can't use just any random router.
    And yes after connecting the phones to your router it's all cake from there on.
  7. jmorley
    Sep 29, 2010
    14
    Ok, yeah i don't think i have a POE router...just a Verizon Fios router. So, to be clear, if i have the power cable, do i need the POE? If i do need a POE switch...how much. I am a home office user and don't feel like paying $$$ for a huge switch.
    Jordan
    edit: what about the yealink....is it easier or am i getting in over my head with VOIP phones?
  8. LeonidasG
    Nov 19, 2008
    1,400
    79
    Power over ethernet = The routers that give Power Over Ethernet simply just add some extra power to your ethernet cable.
    So when you connect your ethernet cable to your phone, the phone will turn on / get power from your ethernet cable and will also work as a normal ethernet cable at the same time.
    You don't really need POE for your cisco. It's just an exotic way of powering up your phone with just 1 cable.
    Just buy the power supply for your cisco and you're set.
  9. jmorley
    Sep 29, 2010
    14
    Ok haha, yeah the power supply ill just buy. Now my question is, you say i am all set with the power supply, now do i use wifi or do i still plug into the computer since the router doesn't need to be used anymore with the power supply.
  10. mhanson
    mhanson New Member
    Nov 6, 2008
    186
    Jmorley,
    You still need your router - without it you have no way to allow the phone access to your network.
    You are over-complicating this.
    No matter what, the phone needs to connect to your network via an ethernet cable.
    As for Power, you can use a power cord, or POE, which in your case is not an option.
    If I may offer my advice, it seems that you are new to VoIP, so I wholly recommend you DO NOT ATTEMPT TO USE A CISCO 7900 series phone. These phones can make experience VoIP Veterans bang their heads on their desks. The work that it takes to correctly provision them can be a major undertaking that someone without experience will not be able to accomplish. This is why that series of phones are not on the Preferred or Supported list of 3CX phones.
    If you truly want to get this project off the ground and work your way through this, you should definitely look into one of the phones listed in the Supported or preferred section of the below link.
    http://www.3cx.com/sip-phones/
  11. jmorley
    Sep 29, 2010
    14
    :). thanks guys! I am so not going with any 79xx series, I plan to go with the SPA 525g :)
    Jordan
