new version 1.2.3 failed to register to asterisk
Discussion in 'Android' started by kronosw, Sep 22, 2010.
  1. kronosw
    Sep 22, 2010
    after update to new 3cx version 1.2.3 my milestone with android 2.1-update no longer register to my asterisk pbx, before update i can register, make call and receive call without any problem.
    try delete profile and add again still same.
  2. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    Dump Asteri** and get a 3CX iPBX ;) JK.
  3. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,559
    118
    I seem to be able to connect to asterisk just fine here.
    Maybe you have some routing issues on your internal network / firewalls?
    After checking into this, it seems this is more of an Asterisk Issue than a 3CXPhone issue.
    Check your Extension Settings / Restart your Asterisk server and try again.
    I don't know why but after sometimes Asterisk just stops accepting registrations from the Android Phone.
    Maybe KerryG can shed some light on this.
  4. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Way to throw me under the bus...:)
    I haven't a clue, to be honest I rarely use asterisk-based systems these days.
  5. kronosw
    Sep 22, 2010
    after try different setting, finally can get connected my asterisk and can make call / received but another issue comming up, 3cx make my phone cannot answer / dial normal phone call, when a phone call comming, once i try to answer the call, phone hang. when i try to make call after i press the dial button, the dialer just close.
    after un-install 3cx softphone, my phone back to normal, where can i get the old version 3cx softphone ?
