New version 7 - Inbound Rule Problem
Discussion in '3CX Phone System - General' started by ziptalk, Jan 15, 2009.
  1. ziptalk
    ziptalk New Member
    Nov 16, 2008
    180
    I upgraded to the latest version last night 7.0.4744.0 and was very happy with the addition of sub-folders under extensions. I expect this will developed further in due course, to allow more than 1 teir of sub-folders and profile settings across extensions.
    However, since upgrade I have noticed that only 1 of my simple DID rules do not work as before.
    I have a DDI Range of 01932251900 - 909 on my test ISDN 2e box.
    I have a DDI Range of 01932233960 - 969 on my production 4 x ISDN 2e boxes.
    I discovered that if I made the inbound rule to *0 through to *9, I can do a mapping to the respective internal extension ending with the same number. I deliberately created my rules loose like this, so when I plug in my production ISDNs, I would not have to create additional rules, these rules basically worked for both lots of ranges.
    However I had to amend *9 to *09 for it to match and foward to the extension. e.g. *09 --> 3969 (internal extension number). THIS ONLY AFFECTS INBOUND RULE FOR *9, all the others go to their respective internal extension number!
    The *9 takes it to my ring group 8000. Please see the 3 screenshots below, the first illustrates my DID rules, the second shows the Patton ISDN Gateway, it's 10002 port with it's respective rules. Note the port rule is to go to 8000, and this is the behavious that is taking place with the *9 rule. I have finally shown the *9 rule point to extension 3969 - Any ideas would be appreciate as I have recreated this rule several times, and the only solution is to change it to *09. Am I doing something wrong ?
    Here is my Activity Log as well for the test:
    Code:
    10:20:03.396  [CM503008]: Call(8): Call is terminated
    10:20:01.944  [CM505001]: Ext.3967: Device info: Device Identified: [Man: Snom;Mod: 3xx series;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom320/6.5.16] Transport: [sip:192.168.66.57:5060]
    10:20:01.924  [CM503002]: Call(8): Alerting sip:3967@192.168.66.102:2051;line=s9u19qgb
    10:20:01.784  [CM503004]: Call(8): Calling: HuntGrp8000:3969Ext.3969@[Dev:sip:3969@192.168.66.154:2057;line=yzmyarab]
    10:20:01.784  [CM503004]: Call(8): Calling: HuntGrp8000:3968Ext.3968@[Dev:sip:3968@192.168.66.106:2051;line=d9xuop9s]
    10:20:01.763  [CM503004]: Call(8): Calling: HuntGrp8000:3967Ext.3967@[Dev:sip:3967@192.168.66.102:2051;line=s9u19qgb]
    10:20:01.763  [CM503010]: Making route(s) to <sip:8000@192.168.66.57:5060>
    10:20:01.733  [CM503001]: Call(8): Incoming call from anonymous@(Ln.10002@Patton ISDN Gateway) to <sip:8000@192.168.66.57:5060>
    10:20:01.723  [CM503012]: Inbound office hours rule (unnamed) for 10002 forwards to DN:8000
    10:13:43.069  [CM503008]: Call(7): Call is terminated
      File size:
      26.4 KB
      1,951
      File size:
      72 KB
      1,951
      File size:
      52.5 KB
      1,950
  2. ziptalk
    ziptalk New Member
    Nov 16, 2008
    180
    Anyone got any ideas on this ?
    An inbound rule of mask *8 should redirect to extension 3968, but it doesn't it goes to a ring group ? which is the default on the port, but the inbound rule should match ?
    This only begun happening when I upgraded to the latest version, please can someone put me out of my misery and let me know this is a bug.
    Thanks,
    Lewis
  3. kevin
    kevin Member
    Nov 23, 2006
    316
    Hi Lewis
    If you could set the logging to verbose and post the support info file into this ticket, we will try to look into the matter. Please identify the timestamps we need to look at.
    Regards
    Kevin
  4. Spyklee
    Nov 1, 2007
    45
    Hi Lewis,
    I've experienced a similair experience with our inbound DID rules.
    We've got a Patton 4554 with 2 ISDN lines and 2x4 DID numbers. With the extensions within a group te inbound rules of the second poort of the Patton are ignored.
    Eric
  5. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    We have tried to replicate the issue in question in our test labs, however have not encountered the issue in question.
    At this stage we recommend that you enable Verbose logging and then make a call then does not depict the issue, followed by a second call that does replicate the issue. Kindly send us the Support Info files for review. This will allow us follow the inbound call INVITE and its parameters, to ensure that 3CX is correctly detecting the source line and route then compare the logging of both calls. When submitting these please advise the calling and calling number as well as the time stamp of each.
  6. ziptalk
    ziptalk New Member
    Nov 16, 2008
    180
    Hi William, thanks for your response and taking the time to troubleshoot this. I had upgraded my version 7 to 7.0.4744 just for the record.
    I have a DID rule *6 that forwards to extension 3966. See verbose log below - but instead now it goes to a ring group with extension 8000!
    Code:
    23:39:44.917  [CM503008]: Call(67): Call is terminated
    23:39:36.445  [CM505001]: Ext.3967: Device info: Device Identified: [Man: Snom;Mod: 3xx series;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [snom320/6.5.16] Transport: [sip:192.168.66.57:5060]
    23:39:36.435  [CM503002]: Call(67): Alerting sip:3967@192.168.66.102:2051;line=9xtzg0pg
    23:39:36.275  [CM503004]: Call(67): Calling: HuntGrp8000:3969Ext.3969@[Dev:sip:3969@192.168.66.154:2057;line=yzmyarab]
    23:39:36.275  [CM503016]: Call(67): Target is not registered: HuntGrp8000:3968Ext.3968
    23:39:36.265  [CM503004]: Call(67): Calling: HuntGrp8000:3967Ext.3967@[Dev:sip:3967@192.168.66.102:2051;line=9xtzg0pg]
    23:39:36.255  [CM503010]: Making route(s) to <sip:8000@192.168.66.57:5060>
    23:39:36.224  [CM503001]: Call(67): Incoming call from anonymous@(Ln.10002@Patton ISDN Gateway) to <sip:8000@192.168.66.57:5060>
    23:39:36.214  [CM503012]: Inbound out-of-office hours rule (unnamed) for 10002 forwards to DN:8000
    23:35:44.361  [CM503008]: Call(66): Call is terminated
    23:35:44.361  [CM502001]: Source info: From: "Lewis Sheridan"<sip:3966@94.185.202.167:5060>;tag=9e24c878<sip:3969@94.185.202.167:5060>
    23:35:44.361  [CM503013]: Call(66): Incoming call rejected, caller is unknown; msg=SipReq:  INVITE 3969@94.185.202.167:5060 tid=ee721c2a4c33c57c cseq=INVITE contact=3966@127.0.0.1:60332 / 2 from(wire)
    23:35:44.071  [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
      INVITE sip:3969@94.185.202.167:5060 SIP/2.0
      Via: SIP/2.0/UDP 192.168.66.57:5080;branch=z9hG4bK-d8754z-ed756f3c1a446457-1---d8754z-;rport=38585;received=94.185.202.161
      Via: SIP/2.0/UDP 82.71.0.209:53334;branch=z9hG4bK-d8754z-tunneltid-1---d8754z-;rport
      Via: SIP/2.0/UDP 127.0.0.1:60332;branch=z9hG4bK-d8754z-5e6dd5031a1d1818-1---d8754z-;rport=60332
      Max-Forwards: 68
      Record-Route: <sip:3cxBridge@192.168.66.57:5080;user=proxy;uri="82.71.0.209:53334">
      Contact: <sip:3966@127.0.0.1:60332>
      To: <sip:3969@94.185.202.167:5060>
      Call-ID: Yjk2OGQyYmFmMWZlYjhjZjIyMzBhMjk3NDBjMjkxM2U.
      CSeq: 1 INVITE
      Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO
      Supported: replaces
      User-Agent: 3CXVoipPhone 3.0.4959.0
      Content-Length: 0
    Previously this worked fine, inbound call would come in, match my mask of *6, and send to the respective extension of 3966.
    However, when I create a new additional rule called *06, this rule works correctly. However I want to have a single rule that works on my test ISDN with a DDI range, and then cut-over to our live system with a different DDI range. All that is important to me is the ....*1-9 mirros to my internal extensions ...*1-9.
    Here is the verbose of it routing when I create the *06 rule.
    Code:
    23:48:59.234  [CM503008]: Call(69): Call is terminated
    23:48:58.163  [CM505001]: Ext.3966: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXVoipPhone 3.0.4959.0] Transport: [sip:192.168.66.57:5060]
    23:48:58.142  [CM503002]: Call(69): Alerting sip:3966@127.0.0.1:60332;rinstance=e14f83077c04d514
    23:48:57.301  [CM503004]: Call(69): Calling: Shared:Ext.3966@[Dev:sip:3966@127.0.0.1:60332;rinstance=e14f83077c04d514, Dev:sip:3966@192.168.66.203:60918;rinstance=f5fed60619d694b8]
    23:48:57.301  [CM503010]: Making route(s) to <sip:3966@192.168.66.57:5060>
    23:48:57.271  [CM503001]: Call(69): Incoming call from anonymous@(Ln.10002@Patton ISDN Gateway) to <sip:3966@192.168.66.57:5060>
    23:48:57.261  [CM503012]: Inbound out-of-office hours rule (Lewis) for 10002 forwards to DN:3966
    Summary:
    *6 no longer matches, and the call goes to the ring group 8000 and *06 will match but will not match when I plug in a different set of ISDN 2e's with a different DDI. Hope those logs help - here is a screenshot of my rules for reference:
    Final Note: This worked fine prior to the upgrade, and affects all my existing rules that comprise *1-9. I look forward to your response.
    Kind Regards, Lewis
  7. ziptalk
    ziptalk New Member
    Nov 16, 2008
    180
    Hi William, I have deleted all the rules and recreated them just now and it appears to be working and behaving normally. Very strange!
    Lewis
  8. doddy
    Feb 1, 2009
    12
    I am getting a similar issue with the latest build. I can add DDI's I can edit DDI's but if I delete a DDI then all DDI then fail and the ONLY recovery is to delete all DDI's and add them back again. I have also seen problems of all DDI's faikling when the 16 DDI was added.
    This is an incredibly annoying issue and which has caused a huge amount of investigation this weekend. we have built the system on multiple environments includiong clean W2003, W2008, IIS and Cassini and the problem exists in all conditions. All DDI are on the same single PSTN trunk
