Solved New Yealink Templates Not Downloading
Discussion in '3CX Phone System - General' started by Brett Coleman, Feb 15, 2018.
  1. Brett Coleman
    Jun 20, 2017
    27
    I tried downloading these updates last and this week...and they are still showing as needing to be downloaded.
    Any ideas on how to fix?
    Thanks,
    Brett
  2. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,441
    189
    There has been a service pack release between now and then (last Thursday) confirm you have upgraded to SP3 as this did include some new templates.
    If this is not the case however the only thing I have known that would stop these updates from happening would be poor or not direct internet access on time of download.
  3. Brett Coleman
    Jun 20, 2017
    27
    Updates should install automatically...the dashboard shows:
    Activated PRO 15.5.3849.1
    So I am guessing that I am not getting the latest updates.
  4. eddv123
    Aug 15, 2017
    1,441
    189
    You 3CX Service Pack won't update until you traverse to the updates page and manually download.
    I am on SP3 and it is currently version: 15.5.8801.3 so yes I would agree, I don't think you are getting your updates, is everything else working with the PBX ? are you in valid Maintenance ? check your dashboard.
  5. Brett Coleman
    Jun 20, 2017
    27
    Maintenance is good through end of June 2018.
    We are running on the GCE so I wonder if that is a portion of the fail.
  6. Brett Coleman
    Jun 20, 2017
    27
    There is no option to download any Service Packs.
  7. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,455
    541
    Hello @Brett Coleman
    Are you getting an error when manually trying to download the updates? Do you have valid maintenance?
  8. Brett Coleman
    Jun 20, 2017
    27
    The only update available is for Yealink templates and no error message appears.
  9. Brett Coleman
    Jun 20, 2017
    27
  10. YiannisH_3CX
    May 10, 2016
    7,455
    541
