[Newbie] Audio prompt not playing?
Discussion in 'CRM / Helpdesk / App Integration' started by MikeMelga, Feb 27, 2014.
  1. MikeMelga
    Mar 15, 2011
    77
    Hi.
    I've just deployed my first basic IVR with just a menu component.
    I've set the menu's 'Initial prompt' property to an audio file prompt and set it's path.
    Build and deploy were successful.
    However on testing...the menu works but the audio prompt does not play. Why?
    (tested with barge in set to true and false - although it should not affect it)
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Are you placing the audio files into the Audio folder and selecting them from there?
    Have you tried with the samples included with the VAD installation?
  3. MikeMelga
    Mar 15, 2011
    77
    Yes. They do not play also.
    No. Where is the audio folder?
    I just entered the full path in the 'Audio File Name' property of the Initial prompt collection. It seems to now the file is there because if I point to a non existing file it immediately gives me build errors.
  4. VAD_Support
    Aug 6, 2009
    690
    When you create a VAD project, there is an "Audio" folder into the project file structure. You need to place the audio files in there. That way, when you deploy the project, the audio files are uploaded to the server.
  5. MikeMelga
    Mar 15, 2011
    77
    Got it.
    Thanks.
