[Newbie] Development tools?
Discussion in '3CX Phone System - General' started by axtens, Nov 21, 2011.
  1. axtens
    Nov 21, 2011
    I've taken a look at VAD and I'm fairly sure it a little too code-less to be useful (to me at least.)
    What other development tools are there for 3CX?
    Kind regards,
    Bruce.
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Depends what you want to achieve.
    There are APIs for integration with external applications (like CRM) and generally you can control calls in your 3CX system in full extend (search the blog / forums).
    Regards
